Bill D
- Apr 1, 2004
- Modesto, CA USA
I am testing a small single phase motor. Right now I have hot and neutral connected but the ground wire is just floating. Not touching anything. there is no wiring box or terminals so easier to leave ground alone until it is running.
it is sitting on dry concrete, outdoors. When i plug it in it jumps then trips the GFCi off. I do not understand why the gfci trips. It should be equal current in and out of the motor with no imbalance going anywhere. Even if the metal outer case was electrically hot I would think the concrete would be a good enough insulator since it has not rained for several months. But the humidity is high today 39%.
I thought for a GFCI to trip current in had to be unbalanced to current out. Normally that imbalance would be flowing to ground. AFAIK a direct short from hot to neutral will not rip a GCFI off since current in and out is equal.
Bill D
Bill D
