Quote by ABarnsley:
"Problem with standard Cat 5/6 for control wiring is ... It is not shielded like the manual requires... Stray RF can cause accidental starts or worse...
Please read your install manual... You might save an arm or something...
THERE SHOULD BE NO DOWNSIDES TO CONTROL WIRING... No special things to remember, no chance another can activate machine while you are working on it..
On means on, Off is off, and speed is adjustable... One pot set to high, one set to low, can only cause problems.."
Gentlemen,
Rather than open yet another ad nauseum newby control wiring help request thread I have hit upon this one - departing from ABarnsley's inimitable "cut to the chase" style. I am a big fan of ABarnsley's "mince no words" writing style and his "keep it simple stupid" advice.
Our project is a South Bend 10L lathe that I just got running last night for my dear wife, Alma, who is a newly minted machinist. Alma is "vertically challenged" at barely 5 feet tall. She is also an intensely "hands on" kind of girl. That is politically correct speech for "monkey see monkey do". Seriously, she is all over everything she does.
So here is my dilemma. I am trying not just to successfully wire the remote controls, but to make them ergonomic for her - not only as regards her stature, but also, her aggressive work style.
This lathe is a 1962 10L tool room collet lathe. It has (or had) a 3 position toggle switch mid-ships on the back side of the lathe. This of course requires the operator to reach ACROSS the arc of death to perform the forward - stop - reverse operations.
The drum switch has now been removed from its original position. At present, the machine's functions are controlled from the keypad on the VFD, a Teco JNEV 201-H1. In a little while I will post a picture if I can find the camera. But for now, let me say that the VFD is mounted on the wall at a convenient height just past the tail stock and barely higher than the height of the built-in collet tray.
So, in keeping with ABarnsley's quoted advice, my next objective is to do a control circuitry installation that is intuitive and as "in your face" as possible.
Here are some components that I have available:
a) about 18' of the proper triple shielded 18 gauge control wiring;
b) the original South Bend drum switch;
c) a "traffic light" style push-button box from some other equipment;
d) a Square D foot pedal.***
***As to the foot pedal: I'm not sure about how its contactors work. I don't know if it toggles on and off with a push of the pedal or if it is "on" while your foot's on it and "off" when you remove your foot.
The first thing I'd like to ask everybody is if you consider a foot pedal controlled on/off (emergency stop basically) to be a good or a bad idea. And of course, I'd appreciate knowing the basis of your opinion.
Next, I'd appreciate opinions on whether I might use the 3 position drum switch mounted somewhere forward on the apron and possibly use the foot switch as some kind of lock-out. In other words, the foot switch over-rides the drum switch.
But the three overriding objectives are: safety, simplicity, and reliability. We are not concerned with "convenience" or "production efficiency" except to the extent that these are complementary sub-sets of the three objectives.
If I get a thumbs down on the foot pedal switch generally, I will forget about it. If there is any enthusiasm for it, I will appreciate some specific advice on how it might be utilized.
As to the drum switch: I'm not sure if there is any difference between "stop" and "emergency stop". Anyway, all comments and suggestions will be eagerly consumed.
Thanks!
Vernon
