kb0thn
- May 15, 2008
- Winona, MN, USA
Hi Guys,
I have a part that will be going into a product we make. Basically it's a 1.34" diameter hole at a 45 degree angle through 1/4" stainless. I seldom do angled entry holes and I am looking for suggestions on a machining strategy for the angled hole.
I can easily have the profile and small holes laser cut on a 2-axis laser. And could laser cut out none or most of the angled hole normal to the flat face. Machine to do the angled hole would be modern Mazak VMC with CAT40 spindle. I was thinking I could do soft jaws with angled slots to allow two of these parts in a single vise. We have 300 of these to do and we'll have probably smaller quantities to do every year forever.
My default thought would be just a use a big solid carbide end mill and helical interpolate. Probably have the laser remove as much material as possible. I use insert drills with great success, but I am not sure how well they would do on the angled surface. I'd like to have relatively burr free faces so we can immediate weld without needing substantial deburring.
Any other, hopefully better, suggestions?
I did put a few RFQ's out to 5-axis laser and waterjet job shops. But they seem relatively few and far between. What I have found seem like they want to make this a $50 part. If that's the case, I'd rather get a $7 2-axis burnout and put a $7 hole in it in-house.
Thanks!
Thanks!
