GrievousAngel
- Jun 2, 2021
I need to connect two pieces of 1/2 Thin Wall together. One 8" long piece has both ends open. The other piece is a bent piece with the business end open. I am hoping to avoid welding them. There is no significant loading forces as it is needed hang compressor gauges and quick connect valves.
I have considered external threading of two piece ⅝" x 2" long 1018 or 1144 round stock, then tapping a ¼-20 centered through hole. Then tapping internal ⅝-11 threads into each end of the pipes. The idea being to thread the two custom ⅝"-11 plugs into each pipe. Then using ¼-20 10" all-thread to draw the pipes together. Well ... it needs to be simpler.
So I am looking into 1/4-20 jack nuts or well nuts or similar. A 5/16 or ⅜ threaded rod would require larger jack nut, etc. that may expand tightly into a ⅝" opening that is OK.
I hope I explained this clearly without having a drawing. Any ideas? Yeah, I know, why don't I weld them together? I would have to take it to a welding shop or buy me a $300 hobby MIG welding. Maybe that is the better choice.
