Nothing, if everything fits. Did you check?
You're using a furnace motor? Perhaps if you explain yourself someone could give you an answer. This isn't the Riddle Channel.
I agree that it doesn’t look factory with only two bolts connecting in the rear. Based on some other pictures you have posted of the lathe I don’t think the stand is South Bend factory issue for a 10K lathe but I am probably wrong.
I would try and see if there is space behind the bed to mount the motor jackshaft assembly directly to the bottom of the chip pan. If not then maybe a sub plate under the assembly that extends forward enough to pick up the front mount hole and into the chip pan enough for two bolts with spacers to bolt through the chip pan.
Or it will probably work fine as is with only the two rear bolts. There isn’t much load on that plate with most of the forces being between the belt and belt tensioner rod. The plate just needs to support the weight of the assembly and the light shear and bending moment load on the two bolts.
Just some thoughts. Hope this helps.
Ben
Like I said, if you did your homework, you did nothing wrong. So, I asked you and you had no idea what I was asking. The answer of course is you have not done your homework because you don't know.
We have not discussed the motor selection. I hope you have done this correctly because it can effect everything above if the motor is too large.
I suggest to make an adaptor plate that pivots first to mount this motor. One side of the adaptor will mount to the countershaft casting. The other plate connected by a hinge pin mounts to the motor frame. You can use a simple bolt with a lock nut to adjust the V belt tension.Keep this adaptor assembly as thin as possible to conserve space.once that is done, you can use shims to position the countershaft assembly in height to establish dimension 1.
I’m a visual person, I’m having trouble picturing an adaptor plate that pivots.
I think the existing motor mount plate does pivot to tension the v belt.
I wonder if that mount was actually designed for a lathe that did not have that type of cabinet or chip pan. Were it me I would fab a plate that raised the motor mount up to clear the existing chip pan and bolt it down flush with 3 bolts. As to the level, I assume you already leveled the lathe. If so, and you want to level the bracket, you will probably need to shim it out. I don't think it matters too much however since it shouldn't reduce the amount of belt adjustment significantly. It should be plumb perpendicular so there is alignment of the flat belt sheaves. (oh also, how accurate is your .59 cent horrible freight level by the way...) just funning you, sometimes you need a thick skin on this forum, but most times people are pretty helpful. Jim
Notice
