Dan from Oakland
- Sep 15, 2005
- Oakland, CA
Nice job! That's all that needs to be said.
I found several sand inclusions in the vises. At least one of them was visible before machining. I also found two large voids in the base of one of the 4 vise halves I machined.
The larger of the two voids was at least 5/8" deep at two points, and was triangular shaped with the triangle legs being more than an inch in length. I did not feel that I could or should fill the larger void with brass, so I made some steel patches that I brazed in. The larger steel patch is 1/4" thick. After brazing and cooling (24 hours in a bucket of dry sand), I cleaned the vise half with a needle scaler (also does some stress relief), and machined the surface flat.
WOW!
Is it really that old?
I have one just like it as a spare.
Never thrown juice to it yet.
Did pirate the nearly new drive wheel off of it to swap to the newer saw that we run regularly tho.
I was guessing maybe the 50's, I hadn't considered it possibly being a war machine!
This one takes a 1" blade tho.
Think Snow Eh!
Ox
I wouldn't put that much work into a bandsaw. If you're going to rebuild a machine, at least pick one that does more than saw material up.
D'arcy saw has them in a couple levels of performance. I think they are between $50 and $90. The poly I intend to use was $15 on Ebay.I bought flat belt from McMaster since I couldn't git it [at the time] from "Amada".
But it stretches pretty bad, and I just put a block of something up in there with a C-cramp and adjust as needed.
I have had to replace the replacement belt already I think too.
Whatever was on it when I bought it [back around 2000?] lasted me the better part of 20 yrs, not to mention however old it was at the time I bought it.
Think Snow Eh!
Ox
Notice
