The blind taper pin I was referring to is in the first picture. As mentioned, it holds the outer spacer of the angular contact bearings. If you pulled this pin when you were trying to get the lead screw out, you may have created misalignment of the bearing or the spacer which could have made reinstallation difficult.
Also, the second picture is of the end plugs. These all must be removed when you get to the disassembly of the feedbox to gain access to the various shafts.
On the back side of the feedbox, there is a plate with several taper-headed screws in it. Behind this plate is a reservoir for all the different oil passages. There are quite a few. Each one has a pipe cleaner that is of a specific length for that tube. Shorter ones deliver oil quicker than the longer ones. I tried to duplicate the type and length of these cleaners. They work a little like a crude meter valve. Each copper tube goes to a bearing or set of bearings where it’s brad riveted to the casting, cut to an angle and taper, then the end of the tube is bent over to the race of the bearing. This allows the oil to drip to the races of the bearing. There are quite a few of these.
As far as getting the feedbox off the lathe, I use a forklift under the feedbox and then slid it off onto the forks.
I’ve also included some pictures of wrenches I made for the Pacemaker. The large one is a L-1 for the spindle. The other is of a spanner wrench that is needed to adjust the clutch for the spindle. (There is a picture of what I am talking about.) Another is an L-0 spanner wrench for the Rivett spindle. I included a picture of it because I like my design and if I were to make any more, this is the design I would use. It can be held captive on the nut (meaning no risk of dropping it), or it can be used without engaging it fully and using one lug as a conventional spanner. The next to the last picture is the wrench disengaged only using one lug. The last picture is the wrench fully engaged - meaning the wrench is captive.
View attachment 372798 View attachment 372802 View attachment 372805 View attachment 372806 View attachment 372807 View attachment 372808 View attachment 372810 View attachment 372809
