Hi to all,
so, at first, following advice of a good friend, I tried to go conservatively and try to flush the dirt off. After spending 1-2 hrs with spray cans and compressed air I got sick of it, no actual progress. In hindsight, it was apparent why
Dirt was coming out very slowly, fit is tight there.
Here you can also see the hole shape. There is the counterbore for the screw head, there is a 7mm through hole and then there is the M6 thread in the main headstock casting. 7mm cried for M8x1 and that's what it got. No drama, using Peter's advice for the headless screws in the M6 thread (thanks Peter!) and it started coming out without real force, nice, slowly and satisfactorily. M6 headless screws had bottomed down so there was no chance they would be turned by the pushing screws and length was such that the female M6 thread was protected.
Behind the ring cover was the pic seen before with the lock clamp and after removing that one as well:
It is apparent that
- there was no way to flush this thing off from the outside
- there was no way that the lock clamp would work as smoothly as on my FP2 with all that crap in there.
Now it looks a bit better, but still some polishing to do:
And the parts before cleaning:
After cleaning the ring I did a test fit on the quill. It's the same, extremely tight fit as the one between the quill and the main casting bore.
I am pretty confident that, provided the fit, if all is cleaned, smooth and burr free, there is no way this ring can end up misaligned. There couldn't be a better installation guide that the quill itself.
But we'll have to see about that I guess...
BR,
Thanos
PS1. I am not sure if I'll go on and install everything back on or if I am going to wait for the Kluber to arrive in order to do the horizontal before installing it. I've always found it very difficult to install the horizontal quill on these machines (and this one is much heavier than the FP2's) and I would like to avoid doing it twice...
PS2. Can't compare slide hammering something like this out to using nice fine threads as pushers taking all the time you want and going in circles (or criss-cross) in order to do it evenly. You would need 4 slide hammers hanging horizontally from 3-4 mm of thread engagement and magic hands to use them.
