Hi all,
Has anyone swapped an optical spindle encoder for a magnetic encoder on a HAAS of a similar age, and have the parameters they changed handy?
We've got a '95 VF-0. The last guy with my job replaced spindle encoder with a magnetic encoder, and we are unable to rigid tap now.
Our HFO hasn't been much help and just kept telling me that out machine is old and changing an encoder wouldn't make rigid tapping stop working.
I think that I am most of the way through figuring out how to get rigid tapping to work again and am looking for a little bit of information and a sanity check.
I believe that the original encoder was optical, and that there should have been a sheet of parameters for the spindle encoder steps/rev, acceleration, and deceleration, that came with the new magnetic encoder.
I found a set of parameters on the HAAS website for that should be changed when installing a magnetic encoder in place of an optical encoder, and according to the document I need to change 79,182,186,187, and 239.
The only parameter in the machine that matches this document is 79. I changed 79 and the tapping cycle looks mostly right, but the spindle isn't stopping completely to orient before the tapping cycle.
So I think that the spindle acceleration/deceleration need to be changed (this looks like parameter 120 in this control, and not the 186 and 187 used in the document provided by HAAS). So maybe the document is for NGC controllers and I need the pre NGC document.
Thanks in advance.
Thanks in advance.
