2017 Kent Lathe TRL1340 - Vermont
B88I45
Jul 6, 2016
I purchased two of these Lathes from an auction, one went to my brother and I was keeping the 2nd. We just had the land behind us pop up for sale, I don't want to sell the lathe but I also want the land for a new shop and shooting range so here it is. Asking $9500.
Kent Link: TRL - 1340 Specs
2017 Kent TRL1340, almost no use, only found brass and aluminum chips. Still has the plastic on the sheet metal plates.
5hp 220v 3 Phase 2 speed motor
Aloris BXA QCTP
Steady Rest
Follow Rest
Coolant pump
Fagor DRO
Tool box with factory accessories
I pulled my phase convertor out of storage to run it. If you'd like a video of it running, I can do that as well.
The bad:
No chuck, I kept the 4-jaw for my brother.
The fiberglass cover was cut to install a collet closer. (Closer not included)
DRO has some dim cells, they show up a little better in the picture.
There are a few dings in the cross slide, see pictures.
I did some paint touch up and have a little more to do on the dark gray bases and brake.
The lathe is right inside the door of my garage and on a skid, a roll back wrecker would take 5 minutes to load. I also have a truck and trailer and am willing to spend a Saturday/Sunday in the New England area delivering it. I head to NW Ohio on a monthly basis, if you're along 80/90 or around Toledo/Fort Wayne/Detroit, I'd be willing to discuss options. If I'm transporting, we'd need to go over some details 1st. The lathe is located in Barre, Vermont, my email is [email protected] and my number is 7576042649. Texting is best to reach me, I may or may not be available to answer calls 8-5pm, but will call back asap. I also have more pictures, if you don't see what you need, I will get them for you.
Ohio buyers, If you're on the fence about these lathes and would like to see one, I can arrange a visit to see my brother's lathe. They are exact copies.
Yes it is a gap bed, I've attached a picture of it with the 4 jaw chuck. I'm in the Barre area.
Should a Chaiwan lathe cost this much? Looks just like the Precision Mathews no? Not trying to flame - just curious about the market as I'm always looking for a larger lathe and this one is a pretty good size/well equipped!
Those tapered jackscrews for locating the gap piece are similar to what's keying my SIP's columns to the base. Nice design detail.
I was taken back when I got the quote from Kent. My landed price from Kent is a little over 19k with the DRO, Aloris and freight. This is direct from Kent so maybe your local dealer can work with you. If anyone is interested I can private message you the quote.
As to the PM lathes. I think the closest option from PM is their 1440 and is 450lbs less than the smaller Kent. I have not seen one in person so can't really say what other differences there are but the controls do look a little cheaper. Those cost 13.5k shipped but you get the larger swing and a warranty.
The lathe is clean and not a project. We had the other one leveled and cutting a couple hours after we unloaded it.
Nice lathe, I wish I had the room for a lathe that long. It's in better shape than the shorter one I have, that's for sure, and couldn't be closer to home.
Good luck with it!
Good luck with it!
Thanks, if you find room or know anyone else who would be interested just let me know.
