Well, you have gone from saying all single phase units in all hospitals give a Proper 208 reading which is complete hogwash. T....
But there is no way that all single phase outlets are 208 as you stated in the first post by you that I quoted in this post.
Denis
Denis
From my experience, when in the USA someone is talking about a "single phase" supply or device or equipment or anything, they do in fact mean
2 hot legs ( L1 and L2 ), a Ground, and ONLY!!! in some cases a Neutral.
OTOH, I have never - in the last 31 years - ever heard anyone referring to a plane-jane 120V outlet as "single phase".
So, perhaps in your neck of the woods it is commonly accepted as such - in which case I apologize - in my area single phase means L1 and L2, 2 hot legs, line voltage, 240V or nothing but phase.
A standard 120V outlet or device or equipment is just that, 120V and is never called "single phase".
Or to put it in the perspective of the "machining" world, a Bridgeport or engine lathe typically uses 3 phase supply, an average size welder or compressor uses single phase, while
your computer is 120V regular power.
And yes, back in the mid 2000-s, ultrasound carts were humongous enough that a 120V supply would have required 30A or more, so they pretty much were
always much easier to be run off 208V "single phase".
Now as to the actual definition, I don't necessarily agree with the definition "single phase" as it really suggest 1 phase and 1 Neutral, but it is defined as such
in common terminology nonetheless.
