3 6" lathe chucks and a few other items.
lazz
Feb 12, 2012
The warm desert of Phoenix Arizona
As usual I dont care about payment.... Mail me a check.... paypal ...either works for me.
First dibs are awarded to the first post. Send a follow up PM and tell me how you wanna pay and Ill get you the necessary details.
Shipping.... Everything will be plus shipping....Im sending this via USPS flat rate boxes.... The cheapest rate possible....
A)<<<SPOKEN FOR>>> 6" Logan chuck. single set of jaws,Unknown backing plate... $40
B)<<<SPOKEN FOR>>> 6" Buck 3 jaw true adjust with reversible jaws. d1-6 backing plate? $245
C) 6" buck 2 jaw true adjust with reversible jaws, no backing plate $160
D)<<<SPOKEN FOR>>> Adjustable mag block $40
E) Jacob 3/16- 3/4 drill chuck and key on MT#4 $50
F) Jacob 14n and key on MT#4 nice and smooth $70
G) Riten 51604 live center on MT#4 lightly used $165
H) unused import 3/16-3/4 keyless with MT #2 $30
I) <<<SPOKEN FOR>>>Mag block 1 1/8 x 1 5/8 x 3 stained $5
K)<<<SPOKEN FOR>>> Mag block 3/8xx 3/4 x 3 with its very own hole. $5
L)<<<SPOKEN FOR>>> Mag block pair 3/8 x 1 1/4 x 3 Stained $15
M)<<<SPOKEN FOR>>> Mag block pair 11/16 x 1 1/2 x 3 stained $20
N)<<<SPOKEN FOR>>> Mag block pair holed 1 x 13/4 x 3 3/4 george scheer co $22.50
O)<<<SPOKEN FOR>>> Mag block pair 1 x 2 x 4 Taft Peirce #359R (5) 1/4 wide 1/16 deep slots $25
P1,2,3) Shop made ? 5/8" X 6 RH ACME $10 each
Q1,2,3,4) Shop made? 1/2" x 6 RH ACME $10 each
R) <<<SPOKEN FOR>>>mandrels 1/4", 5/16" x 3, 3/8" x2, 7/16", 1/2" x 2, 9/16", 5/8", 11/16", 3/4" and 3 shop made. $75
A) 6" Logan chuck. single set of jaws,Unknown backing plate... $40
B) 6" Buck 3 jaw true adjust with reversible jaws. d1-6 backing plate? $245
D) Adjustable mag block $40
I) Mag block 1 1/8 x 1 5/8 x 3 stained $5
K) Mag block 3/8xx 3/4 x 3 with its very own hole. $5
L) Mag block pair 3/8 x 1 1/4 x 3 Stained $15
M) Mag block pair 11/16 x 1 1/2 x 3 stained $20
N) Mag block pair holed 1 x 13/4 x 3 3/4 george scheer co $22.50
O) Mag block pair 1 x 2 x 4 Taft Peirce #359R (5) 1/4 wide 1/16 deep slots $25
R) mandrels 1/4", 5/16" x 3, 3/8" x2, 7/16", 1/2" x 2, 9/16", 5/8", 11/16", 3/4" and 3 shop made. $75
I would like the mandrels which is "R"
Convoed
Whats left
A) <<<SPOKEN FOR>>>6" Logan chuck. single set of jaws,Unknown backing plate... $40
B) <<<SPOKEN FOR>>>6" Buck 3 jaw true adjust with reversible jaws. d1-6 backing plate? $245
If you can use some MT#4 drill chucks or a live center. Lets make a deal.
When would a 2 jaw chuck be the only option?
Are two jaw chucks typically self centering?
There's never an "only" option :) but for some things, two jaws is easy. This is a bad example for a 6" chuck but you get the idea ... grab it by the arm, turn the shaft
or another case would be, any time you want to work on a rectangular or square object, like these heavy-duty main bearing caps ? Bolt two together, drop them in the two-jaw located on the corners and turn your heart out
It's not something you'd use all the time but when you have a need, they work good. Way easier and more effective than milling.
I do some blacksmith texture on solid steel posts, 1 1/2" sq. After doing the smith work these are no longer precise or square by any measure of accuracy. I use a 2 jaw with V shaped jaws to grab the square post end to drill and tap the other end. In this case the two V jaws grabbed the uneven sq way better than the 4 jaw, and also way faster.
Another good use is to grab raw castings with appropriate shaped jaws.
