I purchased a used 3 phase package AC unit for my home shop. I also recently moved, and when I bought the house, I noticed there where 3 phase power lines very close to the property. I figured it wouldn't be much to have the power company setup a transformer and run 3 phase to my property, however they gave me a ball park estimate of 20,000. Obviously that's way to much, I personally think its a BS price, but maybe there are some hidden costs that I cant account for. Anyways I have a 200 Amp panel, and I have a few 3 phase machines that I want to run. A 1hp Bridgeport, a 3hp lathe, the 5 ton AC, and my big old 30hp Haas HS-1. The Bridgeport and lathe already have VFD's, and I was thinking about getting an American rotary AD rotary phase converter for the Haas.
That just leaves the AC unit. It draws about 15 amps on a 3 phase circuit, I ran it on a 20 amp circuit to test it out before I bought it, and it had no issue at all. When I hooked it up to test I could tell that the only thing using the 3 phase was the compressor. the blower and all other electronics run on single phase 220. I plan to order a VFD to run the compressor, which will be much less expensive than a rotary phased converter. I also dont want to run on the same rotary phase converter as the Haas. When I get a chance Ill tear into and see what size the compressor motor is, and if it really is the only 3 phase component.
Also I live in PHX, so having an AC for the shop goes a long way.
Has anyone done anything like this before.
