M. Moore
- Jun 8, 2007
- Vancouver Island, B.C. Canada
I have 120/208 3ph to my shop. I use a 208 to 480 volt transformer to run my Webb pyramid rolls. Today the roll motor started acting funny, thought it was the motor brake but that checked out ok. Temporarily removed the brake and the roll motor worked fine. Re-installed the brake and hit forward switch, rolls moved fine. Hit reverse and the brake chattered, motor didn’t move.
So I started checking voltages at the main disconnect and at the roll contactors. Was getting a crazy high voltage at the contactor? Like 600, 800, 575, sometimes 0, very strange.
The 208 to the transformer is fine. After the transformer it is very strange and this after the rolls worked for one test and then stopped again. . Transformer has always had a buzz sound when on and that sound has not changed nor is there any bad smell of burnt insulation.
I have not pulled the cover off the transformer yet. Having lunch now and wanted to ask about this weird high voltage. I think it is a 15 kva size but will check. All the wiring is sized correctly and it has been running for at least six years. I don’t use it often but it also runs my heat treat furnace and my plasma cutter. Those three I don’t use often but I do use it to run my drill press and I use that all the time.
Any ideas on what this could be? I will try my other meter just to make sure it is not the meter. However something is not right given the motor problem on the rolls.
