Hey all,
We run Haas rotaries on the right hand side of our tables with A-frame supports on the left side as needed. My process has always been getting the rotary straight and square, then bolting the fixture to the face plate of the rotary, then using shims on the A frame to get the A frame bearings on axis with the rotary. If the fixture slopes down from right to left, i would shim under the A frame on the left until my indicator shows it straight.
Lately I've been seeing some of the set up staff in my shop doing this differently. If it slopes down from right to left, they leave the A frame as-is and shim between the rotary face and the mating surface of the fixture. This strikes me as problematic... Then your fixture is on axis for one orientation but thrown out any time you rotate.
Am i wrong? Are they both equally valid and im just nit picking?
