We've recently had our first 5 axis delivered, Mazak CV5, 730mm X stroke, reasonably small machine.
We're seeing the centres of rotation move around with temperature about 20-40 microns (about a thou) depending on temperature change machine warm up etc, which is really f**king me up as I'm trying to set up for a part where I've got to hold 5 microns on a blend between two toolpaths (2 tenths).
Obviously there will be some thermal movement but I was expecting it to be microns (from the machine's perspective) with all the thermal comp software etc.
If you have a 5 axis, how much do you see the centres move? Or what kind of tolerances are you able to hold day to day with the rotary axis' moving?
Thanks in advance.
Thanks in advance.
