Zero Tolerance
- May 13, 2021
INJECTION MOLDING PRESS FOR SALE!
60 TON 4.0OZ BARREL
$68,000 OR BEST OFFER
Located in Clinton Twp Michigan 48038
DETAILS BELOW:
Wittmann Battenfeld SmartPower 60-210 Injection Mold Press
Year Of Mfg: 2020 - LIKE NEW!!! (WE JUST NEED A LARGER PRESS)
Hours as of 12/14/2022: 2,671
CNC Control: Wittmann NC Manager V2.52
Clamping Force: 60 Tons
Opening Force: 3.8 Tons
Distance Between Tie Bars: 14.56" x 12.59"
Minimum Mold Height: 7.87"
Max. Daylight: 23.62"
Opening Stroke Length: 15.75"
Ejector Stroke Length: 5.91"
Ejector Force: 3 Tons
Nozzle Radius: 1/2"
Nozzle Stroke: 9.84"
Nozzle Contact Force: 9.7 Tons
Injection Unit Screw Diameter: 1.18"
Screw L/D ration: 22
Specific Injection Pressure: 1500 bar
Theoretical Shot Volume: 144 cm3
Max. Shot Weight: 4 Oz.
Electrical: 440 to 480 volt, 3 phase, 60 Hz
Overall Dimensions: 11'6" L x 4'4" W x 6'4" H
Overall Weight (approx.): 7,500 lbs.
Equipped With:
Smallest footprint
Traversable injection units with linear movements.
The screw can be removed quickly in just a few easy steps.
Rapid and even build-up of clamping force through a simple, centralized hydraulic clamping system with diagonally symmetrical fast-stroke cylinders and centrally mounted ejector.
Support for the moving platen by high-precision linear guides
Easy, comfortable parts removal in three directions through open drop area.
UNDER POWER & RUNNING PARTS
COME SEE IT ANYTIME
586-630-3032
60 TON 4.0OZ BARREL
DETAILS BELOW:
Nozzle Radius: 1/2"
Equipped With:
Smallest footprint
COME SEE IT ANYTIME
586-630-3032
