More details PLZ. What inserts, what type of drill, etc.
I turn 6061 a fair bit, and IME unless something really goes sideways, it's very stable. Last job was a 1.753" bore 4.75" deep, +/-.001". Once the machine is warmed up and the tools are set, it's pretty straightforward. Material was Kaiser, but also was happy with Hydro.
Regards.
Hey guys, I work for a company called OPW. We make the gas nozzles. And breakaways you see on the hose above your head at the pump. We started using an alternate material when aluminum with short. The OD turning did fine but drilling ID boring is a nightmare. The chips don’t wanna break and there seems to be a lot of heat coming from the material as we try to cut it. We did get it to stabilize, but at the cost of half the parts we normally make. The problem We are still having is when we finish the ID diameters they tend to fluctuates. I have added more than one finish pass, both at different cut depths,(tired).005,.010,.015,.020. Tired PCD, coated, uncoated, stainless grade, But still (depending on the bars, it changes by the bar sometimes) . We can get 10, 20, 30 parts, then the ID will go big or small. We can flip the finishing insert and it goes back to size for another 10, 20, 30 parts. Any ideas would be greatly appreciated. Thanks
Hey Mike, Thanks for replying. So, we are using a 0.937 Seco drill, Inserts SCGX070308-MP , DS2050 (
https://www.secotools.com/article/p_03134314) / SPGX0703-MC , DS4050.(
https://www.secotools.com/article/p_03134321) 35 Degree bore for finishing the seat down in the ID Sandvik VCGX 11 03 04-AL H10.(
https://www.sandvik.coromant.com/en-us/product-details?c=VCGX 11 03 04-AL H10 ) We rough the seat with a 55 degree DCGT11T304-FN2 WNN10 from Walter(
https://www.walter-tools.com/en-us/search/pages/default.aspx/product/dcgt11t304-fn2 wnn10). Then a 80 degree(
https://www.sandvik.coromant.com/en-us/product-details?c=CCGX 09 T3 08-AL H10)that roughs the linear bore leading up to the seat( the 35 finish that as well on the way out.) Rpm we tried up to 4500, right now, we are at 3000 using constant. Feeds for roughing were with the 6262-T6 (original material) were at .024 per rev. now at around .010. and finish was at .008 now down to .003. The drill chips when we started would come out like ribbon candy. So, put pauses in it. for the most part it breaks the chip into a manageable size. Drill runs at 3000rpm and feeds at .006. 6262 we ran 4500 and fed .015
