HickStick_10,
"You can totally clean the barrel and frame of a mike without dissasembly "
Alright, I'll bite - how are you doing this? Do you literally mean total cleanliness, as in confidence that there's nothing lurking inside ?
Does your method work with J.T.Slocomb mics as well as Starrett and B&S ?
(There's another thread somewhere on PM about the ins and outs of dismantling a J.T.Slocomb. Slocomb put a severely-worded warning in their manual cautioning against disassembly. That was dealt with in the other thread.)
Just amazing how much one can learn on PM.
JRR
Badly worded I'l admit.
Mikes (starret, B & S, mitutoyo, no name chinese, moor and wright) are pretty much the same animals. I cant speak for slocomb as I've never seen one (arent they a brand thats no longer made?)
Its would be pretty clear to anyone who's actually used a micrometer if there is anything lurking inside(tight feeling, or it has a crunchy feel perhaps), I should have stated that if the thimble turns fine without a gritty feel to it, and it appears to me well taken care off and reasonably clean, then leave it alone if possible. Wipe off the barrel, and thimble, give everything a light coating of oil and put it back in the box. A mikes a pretty simple tool, and that barrel pretty much covers the thread against any but the most extreme ingress of grit and bad stuff. Il admit if it looks like its been swimming in a barrel of valve grinding compound, you better turn the spindlel out , and clean it more extensively.
Its the same when people completely dissasemble some guns because they think they need to do that to clean it properly, wrong. It usually causes more trouble then it cures.
Plus the OP didn't state (and I assumed, my bad) that the mike was turning stiffly BEFORE he dissasembled, hence it was ok, and probably (me assuming again) only needed a good wipe down.
And when you think about it, MOST measuring tools should not be dissasembled for clean them, as they are well protected to begin with. I'l say right now, do not disassemble dial or electronic vernier calipers, indicators, bore gauges, bore mikes and so forth and so on, unless absolutely necessary.
FWIW: Mitutoyo says not to dissasemble there line of rod inside micrometers as well.
Sorry If I wasn't clear.
edited to add: I just took apart my 6-7 #436 starret to see if i could hit the same problem, and the fellas are right, that little bugger of a ring can screw you up, that ring has a tiny key in it and a tiny key slot facing forward, so the ring must come straight forward, out comes the lock assembly, and open that little slotted ring a bit. Like the gentleman here said.
If you were able to start screwing it in i'd still stick with crap in the thread.
