CC
- Mar 14, 2006
- NW Pennsylvania
So our old ROCKFORD COMPACT PLANER MILL has a badly worn vertical ACME 2.500" - 4 TPI feed screw nut.
I'm going to measure the existing screw using thread wire method and make a external threaded plug gage
that matches the existing screw to use when cutting the nut.
We want to make a new feed nut that fits the existing screw and while re-learning my ACME knowledge I ran across a question.
According to the MACHINERY'S Handbook formulas, the BASIC PITCH DIAMETER of a 2.5"-4TPI is 2.375" for the INTERNAL THREADED NUT.
The formulas also give the PITCH DIAMETER for the EXTERNAL THREAD as 2.3624" MAX.
I did layout of internal and external thread and found that the BASIC PITCH DIAMETER for the NUT is 2.375"
And the MAX PITCH DIAMETER for the SCREW is 2.3624" as the formula states due to the ALLOWANCES..
I'm going to make the nut fit the screw so I'm not worried about the pitch diameter for this job BUT.......
Here's the question: If I were making a new 2.5"-4TPI screw and didn't have the nut, would I use the 2.3624" PITCH DIAMETER to calculate the
BEST WIRE SIZE and DIMENSION OVER WIRES?
