Joe, I'm not questioning you by any means at all and please don't take this question the wrong way. The tech support guy at work that told me about the 200 volts being overseas tells me that this 7.5 hp motor is an oddball for sure. But my question is how confident are you about this being wired to the low voltage? It's that one little sentence at the bottom of the motor label that's causing the confusion for me and him
(200 volt use low voltage connection) but it doesn't bother to mention the 230 voltage, would have been so simple for them to add that part to the sentence and I realize that it could have slipped by, or there's the simple fact that a qualified electrician (not me at all) would be doing the wiring on this thing and it wasn't needed. Would the 230 voltage be considered low voltage because it's in the same column as the 460 voltage? I tried to call Century but the customer service is a nightmare to say the least. The woman told me tech support is only available through email, you can only use the email if you have an account, and you can only have an account if you have a business name, on and on
Does either one of the
View attachment 396383View attachment 396384voltage connections look odd or are they pretty standard looking for someone who knows these things? Again, I definitely don't intend for this to come out the wrong way at all, I'm just saying that one little sentence is bothering me with the limited knowledge that I have on this part of it all. Thank you once again for all the help and advice sir!
