Matthew Dudley
- Sep 13, 2022
Machinists,
I am an apprentice machinist start to build my tool collection. I currently work for a small machine shop that supplies most tools and go to Athens Tech which supplies materials and tools. I recently bought two rolling toolboxes that I plan on filling with tools related to the mill and lathe in separate boxes with some common tools in both. My current buy list will be below. Please let me know what tools y’all think I should add or remove from the list. I am thinking about opening my own shop someday, so I would also appreciate some advice on planning for that. I have completed Introduction to Machining, Mills 1, Heat treatment/ Surface Grinding, and Blueprint (GD&T). My Fall 2022 classes are Lathes 1 and Mills 2. I plan on taking CAD/CAM and Lathes 2 in the spring and graduate Fall 2023 from Athens Technical College Precision Machining and Manufacturing program. Projects I have made so far include: drill gage, lathe test bar, precision ground and heat treated v-blocks, rotary step block, machinist soft face hammer ( turned aluminum 3 components), machinist screw jack, surface gauge and t-handled tap wrench. Machines I have operated include a Cleveland Automatic Screw Machine that was used in World War 2 and a Warner and Swasey turret lathe model 3.
Thanks for the information and advice
Mill Box List:
Mill Box List:
- 1x 6” dial calipers
- 1 set 0-3” micrometers
- 1 box set parallels
- 1 set standard wrenches
- 1 set metric wrenches
- 1 set standard Allen keys
- 1 set metric Allen keys
- 1 vise handle
- 1 pick set
- 1 test indicator set
- 1 set of common taps ( 1/4-20, 1/4-28, 3/8-16, 3/8-24, 1/2-13, 1/2-20…)
- 1 set common end mills (1/4, 3/8, 1/2, 3/4, 1”)
- 1 drill index ( 0-1”, #,letter)
- 1 set R8 collets ( 1/16 - 1)
- 2 keyless drill chucks, R8 shank (0-1/2,1)
- 2 keyed drill chucks, R8 shank with chuck keys (0-1/2,1)
- 1 chip brush
- 1 tap-drill/ decimal equivalent chart)
- 1 machinist handbook
- 1 small surface plate
- 1 small height gauge
- 1 surface gauge with indicator
- 1 set v-blocks
- 2 1-2-3 blocks
- 1 scientific calculator
- 1 tie-down kit
- 1 roll double sided tape
- 1 bottle dyekem
- 1 set writing utensils
- 1 set files
- 1 deburr tool kit
- 1 can tap magic
- 1 oil can of cutting oil
- 1 set 6” calipers
- 1 set standard lathe tools ( HSS turning/facing tool RH/LH, HSS threading tool, HSS chamfer/1/16R undercutting tool, Carbide of all above, knurler, parting tool)
- 1pick set
- Tap wrenches/ die handles
- 2 keyless drill chucks, Morse 4shank (0-1/2,1)
- 2 keyed drill chucks, Morse 4 shank with chuck keys (0-1/2,1)
- 1 chip brush
- 1 bottle dyekem
- 1 Live Center Morse 4 shank
- 1 set Thread Gauges
- 1 set Thread Wires
- 1 set Go/No gauges (common thread sizes)
- 1 set common bolts + nuts
- 1 set gauge pins
- 1 set files
- 1 deburr tool kit
- 1 bottle tap magic
- 1 oil can with cutting oil
