I posted last year about a strange alarm I was getting on a Brother TC-31.
Basically, I am getting a random alarm for an option I don't have. I found where the alarm signal is coming from, and there is nothing plugged into that spot on the I/O board. I measure voltage at the pin, and when it goes above 1.4 V, I get an alarm (It's a 24 V system). It has been hovering around there lately, so it it goes in and out of alarm a lot. I'm guessing that something is shorted internally on the board which is causing a small voltage to be seen at this pin. Do I have any options other than replacing the I/O? I'm guessing not, but I thought I'd ask to see if anyone with more electronic experience than me knows a way my board can be fixed.
Thanks!
strange random alarm on Brother TC-31A
I have a Brother TC-31A with A00 control that is randomly throwing alarm 6311: H Pre Coolant Err 1. Description says "high pressure or filter pump overloaded". The problem is that this machine doesn't have high pressure or through spindle coolant. It has two pumps: flood coolant and washdown...
www.practicalmachinist.com
Thanks!
