gargamel
- Mar 22, 2012
- Boston, MA
Just to be clear, I have the users manual already so I don't need that. The Y axis is only showing a single number. The number flickers when the scale is moved, but thats about it. Its not the scale - if I switch axis cables in the back the problem stays the same.
In the users manual, there is a note for "one or several digits or segments do not light up" which recommends "Faulty axis or display board, component level repair or replacement is required".
So... Does anybody have the actual service manuals of this unit? I know it is probably not worth the time to dig into it but the cheap old yankee in me can't resist at least trying to fix something before casting it aside. It will cost me ~$100 worth of connectors and some time to make adapter cables to use the old acu-rite scales with either a Fagor or RSF DRO that I have available, so I feel like it is at least worth an evaluation to see if I can fix the Acu-Rite box.
Thanks,
Mike
Thanks,
Mike
