Anybody still use 2 flute end mills?
It seems like for square end mills, aluminum specific end mills are 3 flute, and steel are 4 flute variable. I haven't needed to load a 2 flute more than a handful of times in the past year. Anybody still use them regularly, and if so, for what?
I use 2-flute end mills (called slot drills here) a lot, for milling keyways in steel shafts. I have about 40 6mm keyways to cut tomorrow...This is on a manual BP, keyways done in one or maybe two cuts. No Y-axis adjustments needed, a two-flute cutter will cut the correct width. I 'mike' the cutters first and use one that is say 0.03-04mm undersize.
Actually, I like two-flute cutters a lot and use them for other milling too.
Yes, everyday they lie next to my other 4's and 3's. So that nothing jingles around. So they are spacers.
Actually I wonder what I'm going to do with some of these never used 2's. Al and plastics?
I should have used a 2 flute with some Tivar 1000. Trimming plastic for a sharp edge is difficult.
