Hobby Racer
- Apr 18, 2015
I'm re-mating the bed to the base of my 42 round dial 10EE and would like to know if there is a torque specification for the 6 bolts that secure it.
This type of thing is special, you are not in a high stress situation. You want to hold
the bed in place while minimizing any stress applied to the casting. You want to draw
the bolts up tight but not really torque them.
On a 10ee you would in general level the machine as a whole by using the the 3 casters under the base. However, for correcting any bed twist, this would have to be done by the contact area between base and bed.
If it were me in this position, I'd precision level the base with bed removed. Using the bed mounting area as my leveling reference/surface.
... Shimming between the base and bed will add exactly that stress.
I'd prefer to not have to do anything . But cast iron, particularly old iron, changes over time with growth, warpage, etc. Shims already in there is telling me something.
If you happen to own a .0005" level, it costs you about 10 minutes of your time to do a check and see, even if you opt to change nothing. But as a simple experiment, you can learn something with the base level, then watching level on bed as you tighten it down. Best part is you won't need to guess and wonder, you'll see the numbers first hand.
Shimming works but it's not ideal.
Whether that matters or not is up to you to decide.
Believe best practice is to scrape the bed to base fit for proper contact and the factory spec for the bolt torque is actually pretty high.
https://www.practicalmachinist.com/...gearbox-removal-100049/index2.html#post324988
I think you guys are getting off track. Its NOT the headstock I am talking about. It's the bolts that secure the bed itself to the base casting.
The shims I found there appear to be factory originals so I'm going with what they used. My headstock IS scraped in to match the bed, no issues there.
I believe that some of the wartime production machines had some expedients to reduce manufacturing time. My '56 had the bed scraped to the base (or maybe the reverse) so that clamping wouldn't stress things.
It's easy enough to check during the reassembly with marking compound. If there's good contact with the feed unclamped it's pretty hard to add any stress by clamping it, cast iron doesn't compress that much.
Nope, we're talking about the bed to base interface. In my '56 it was scraped in and I just barely had to touch it up in my rebuild, I recall it was about 2 passes to get close to 50% coverage over the feet on the base. So far as I know the intent there is to keep the bed in the same stress as when it was ground by matching the base to the bed feet before clamping.
If I have a .002" twist to the bed with it unbolted and sitting free. . . Then either scrape or shim the bed to mate and contact with base perfectly. . .I would presume I have now incorporated that twist into the final product, and it will still have a .002" twist.
The only way I can see to remove that twist, is to scrape or shim accordingly to pull it straight when tightened down. Could be I'm missing something. But I just can't see neither base or bed holding to inside of .001" from the day it was manufactured till now.
Notice
