Ferrum machining
- Aug 6, 2019
ISSUE:
I got an alarm I can’t get past could you guys help?
MACHINE INFO:
fanuc oi/Mc 2007-2009 campro csp 750i
ALARM:
1120 and 1122
atc arm alarm and atc signal alarm.
WHAT HAPPENS:
It swings the arm to the spindle then it alarms out with the mag pocket down. I’ve tried it twice and both times it alarms out right under the spindle on the first swing.
One thing I’ve noticed that it’s doing different is that there is no extra hissing sound when the un-clamp sequence starts.
WHAT HAVE I TRIED?:
I tried to add a tool manually and it worked and it un-clamped my tool normally (Manually.), but it did not hiss like it usually does.
I checked sensors that influence the tool changer sequence above the spindle on the spindle motor and they seem to be in good condition and working order.
Thanks guys if I need any more info please let me know
MACHINE INFO:
ALARM:
1120 and 1122
WHAT HAPPENS:
WHAT HAVE I TRIED?:
