Automated mirror finish of SS flat parts?
Matte4
Mar 27, 2019
Hello
We machine SS which need mirror finish, so far this has been done manually with an operator holding each piece against a polishing wheel. The parts are at most 5"x3" and .500" thick. The problem is this very inefficient,tiring and everyone hates doing it.
So I am looking for an alternative polishing method, anything that can help automate the process, so does anybody know of automated polishing machines out there? Just anything to get rid of manually holding the parts while polishing them will do.
We polish about 80pieces per 8hour shift, so production rate is not an issue.
DMF_TomB
Dec 13, 2008
Rochester, NY, USA
Hello
saw video once of robot polishing sink faucets and other plumbing stuff. i believe it was doing
a lot per day and humans preferred not to do that as a full time job
CatMan
Apr 12, 2005
Brandon, MS
What sides do you have to do? Just the flat sides, or do you have to get the edges too?
I believe I've seen machines that are basically conveyor belts on the bottom and brushes/rolls/belts on top. You lay the parts on the belt, and it slowly feeds them underneath the polishing mechanism.
DanielG
Oct 22, 2014
Maine
I imagine someone makes something like a timesaver with a polishing belt on it. I've seen them run with non-woven belts on them (e.g. scotchbrite).
1953chevB
Jul 31, 2020
Check into super finish , similar to R.E.M. super finishing. There is guy on my Linkin account that advertises,
Some back ground, it a tumbler debur that has polishing stones. And special chemicals to obtain a mirror finish.
What is the tolerance on the parts?
This procedure removes very little parent material. You can purchase the equipment and chemicals to run in house.
Matte4
Mar 27, 2019
Just have to do the flat sides. so a machine like that would work, any supplier you have in mind?
Matte4
Mar 27, 2019
I will look into this, thank you. I have +/-.015 tolerance on the flat sides, only need the flats polished.
Milland
Jul 6, 2006
Hillsboro, New Hampshire
First off, have you optimized the machining process so that parts need minimal polishing off the machines?
Do you require any flatness, or just a cosmetically shiny surface?
Both sides of the 5 x 3, or just one?
Consider cleaning after polishing, usually some residue is left behind. Whatever method you use has to not damage the surface.
Storage/packing for shipping should be optimized.
Unless flatness is required, I'd not lap the parts unless the lapping machine is in some way converted to conformal polishing with a face-buff wheel. Even so, I'm not sure you could get the speed needed (RPM) without significant modification to the lap, to the point where I doubt it would be economically feasible.
Raking of the buff wheel or scheduled replacement is needed to prevent hard buffing compound or buff wear from compromising the process. You'll need to do some process study to come up with the right parameters.
Safety! Whatever you do, those are sizable pieces of steel, and you must be sure they can't be "tossed" out of the buffer in a way that risks injury to people.
Matte4
Mar 27, 2019
There is a flatness requirement so I guess lapping is not an option here. We have special totes for moving machined product to our de-greasing/cleaning station, therefore residue on the surface is not a problem.
1953chevB
Jul 31, 2020
this true the better the finish at machining the quicker and easier the parts will polish up.
with super finish. it's a time factor the longer in the tub the better the finish.
Mike1974
Nov 5, 2014
Tampa area
A member here recommended Cogsdill to me when I was looking into it. It's expensive as heck though. It is like a facemill but with flat diamonds inserted into it. For a roughly 2.5" model it is almost 4k
Milland
Jul 6, 2006
Well, the OP answered almost none of my questions, so not sure I should bother continuing. But as far as burnishing goes, you'd need to use a highly-filtered coolant/lubricant during the process (unless Cogsdill says different), and that could require adding a filtering unit to whatever machine it's done on.
Screwmachine
Mar 8, 2001
Switzerland
Do you need optical mirror or shiny mirror-like? What's the flatness requirement? These details can take you from fairly simple to orders of magnitude more PIA and expensive.
Mike1974
Nov 5, 2014
Tampa area
Their website says no special coolant needed, and no mention of extra filtration, but I have never used one so I couldn't say.
Milland
Jul 6, 2006
Dunno what they'd say, but if I'm burnishing I'd want to ensure I'm not forcing little particles suspended in the coolant into the workpiece. Bad for finish, bad for the burnishing tool.
