I've become the owner of an old abused Jungner US 2305.
It came originally from a place where it seems the operators liked adjusting the swivel table with a sledge hammer.
It also seems like they used incorrect t-nuts for fixturing as well as overtightened these.
The abuse seems to beyond the raised areas have resulted in a bow in the table. I measure 0.1mm convex in the long direction.
I assume this us from the hammering and general abuse in the t-slot.
I have proceeded to file and stone the dings but there are still raised areas.
Considering if I should rescrape the bottom and regrind the table in situ on the machine.
Stroke is not long enough but i think I can reposition to reach all of it.
Another option is to drag it to work and surface grind it there.
This is probably the better idea.
The questions is what will happen with the bow when re-grinding the top.
If stress us released with grinding then maybe that should be operation one.
The area under the swivel table seems rather undamaged and appears to be paralell with x and y.
Any considerations and recommendations or tips would be welcome.
