Bearing Issue...Never Seen This Before...
michael.kitko
Oct 30, 2012
Pontefract, UK
We have this bearing that failed at my place of work. As you can see, it kind of looks like fluting, but this is the outer housing for the bearing to sit in, not the bearing race, which is where I would expect to see fluting. When it was put in, the bearing had a .002" interference fit and now it measures +.003". The bearing that came out, rotated freely and smoothly by hand. This housing was installed three days before this as a brand new install before it got pulled for an unrelated issue. I am just wondering if anyone has seen this and if so, what caused this wear in this area? Thank you in advance.
Joe Gwinn
Nov 22, 2009
Boston, MA area
I've seen that kind of pattern in the fault-analysis rogues galleries from bearing manufacturers. As I recall, that pattern is due to the outer race rolling around bouncing within the slightly oversize seat in the housing. No way was that outer race pressed in with 0.002 inch of interference, no matter what the drawing or procedure said. By the way, what is the diameter of the outer race?
See also posting #8.
eKretz
Diamond; Mod Squad
Mar 27, 2005
Northwest Indiana, USA
I'm with Joe. I don't see any way that it could have been a real .002" interference fit and come loose like that. The caveat being that someone didn't thoroughly measure for deviations from cylindrical shape and roundness and it didn't actually have that .002" interference fit across the whole diameter. Did *you* actually measure it before the bearing was installed? Or are you relying on someone else for this info? Also, what did the OD of the bearing look like, any photos of that?
To be honest, due to the irregular pattern of the markings, this looks like a housing that was bored with chatter to me. And was slightly oversized from the start due to that.
gbent
Mar 14, 2005
Kansas
That ol' gal sang big time when in the lathe. Way to much spindle speed for limited feed rate.
Joe Gwinn
Nov 22, 2009
Boston, MA area
There is even chatter in the retaining ring groove. Pretty clear it was a bad turning job.
I looked through the SKF failure photos. What I was thinking of is called "ring creep due to inadequate fitting" (meaning too loose), but none looked like the photo in posting #1.
And the bit about seeing the pattern even in the snap-ring groove supports the chatter theory.
mottrhed
Sep 23, 2013
nh
That's not from a bearing, but out of curiosity what kind of bearing goes in there? I presume a cup/cone if you were shooting for a .002 interference? Either way with the thin wall, a .002 interference probably isn't real once installed as the housing likely swells.
kevin66
Apr 1, 2015
Looks like chatter on the finish pass. Just by what I see in the photo I don't think the bore grew by any wear from a spinning outer race since you can still clearly see where the boring bar was retracted at size leaving a witness mark on the way out of the bore.
michael.kitko
Oct 30, 2012
Pontefract, UK
Thank you all for the answers.
1. I watched them fit the bearing and it looked like it was going in like always. I never saw the inside of this one before we fit it.
2. The chatter theory could be correct given that the machine shop they use constantly has wrong dimensions. In fact, the other five of these had wire edges at the bottom facing up.
3. It's a double roller bearing from SKF.
boslab
Jan 6, 2007
wales.uk
Best guess is a heat treatment fault though metallurgical inconsistency could be in the mix, the trading standards folk have caught loads of fake skf bearings up to giant ones, they are all correctly stamped etc but fail, guess where they come from
Mark
Stirling
Dec 11, 2013
Alberta canada
What kind of load is on it?
Belt pulling/loading in one direction, swinging force (vibratory motor?)
I’ve seen housings grow due to load when the wall was too thin or the surface finish too rough (high feel hills/vallys or chatter)
Looking at the finish I’m leaning on the chatter theory.
Another consideration, was it pressed it or was the housing heated to allow it to drop in?
Again with high peaks and valleys pressing in can smooth out the peak tops and you’ll suddenly have a different size.
I used to to LOTS of endbells sleeve repair and we always heated the housing to drop I the sleeve for a stronger bond.
Easa associations literature states it was something like 8 times better hold when a sleeve was placed in w/heat/cold vs pushed levelling out all the peaks and valleys
michael.kitko
Oct 30, 2012
Pontefract, UK
This was on the non-drive side. I did do thermal shots of the housings while they were running on the other housings and noticed that the material these are made out of hold heat a lot better than the aluminum ones these are replacing. I'm personally leaning toward them having a pre-existing chatter in them and the techs that installed the bearings didn't catch it before installation.
