Doug,
There is absolutely no way any automotive engine will survive very long at a 75% loading. They were never deigned to do this. Automotive engines are designed for limited duty applications. Compare any automotive engine design to a continuous duty engine. There are huge differences. This is specifically true in Stephen's case. Please compare his over bored and stroked motor to say a Lycoming aircraft motor.There is a very good reason automotive engines are only rated at peak brake using power pulls rated in seconds as opposed to an SAE rating of work done over time.
Secondly, wear on valves, guides and seats rarely cause catastrophic failure. Even in stock engines, that kind of wear as Stephen specified is very unusual. He should be seriously looking at valve train geometry IE valve length, push rod length and rocker arms. Stephen did not specify if his engine is using after market heads, rockers or cam All of which can drastically effect valve stem loading..
My first line states that it is a 2276 Av conversion.
Originally Great Plains. EMPI heads. Appear to be first run, though heads might not have been refreshed when nikisil cylinders failed, and PO installed steel barrels. This is my first VW in any form. I'm a lot more familiar with small Continentals which i have owned and maintained including flying behind a GO-300 for 6 years.
Back to VW.
As Doug mentions these do cruise at over 75%.
80HP design/dyno at 3600 rpm.
Typical cruise 65 - 70 HP.
Heads (as you are aware) are limited by cooling capacity to about 70HP
They seem to last in this type app for about 250 hrs.
Good bottom ends seem to last "about" 1,000 hrs.
Yes, VW operators more or less say "just get used to changing valves and guides"
Some notes indicate the exhausts get changed anywhere from 2 x to 3x as often as the intakes need attention.
Hence my questions.
& no one has really commented/compared among the 3 commercial solutions.
So far, Ampco 45 keeps turning up from contacts in the industry and so far would probably be my choice if i turn on the lathe instead of buying a solution.
smt, going hiking for the rest of the day.
