Brother HS-300 Cutting Problem
DDesign
Dec 3, 2022
Odessa FL
Hi All,
Having wire breakage with spark energy set to anything above 2. Wire breaks after the first few sparks regardless of settings and the sparking doesn't sound normal. I measured the clamp voltage when it was cutting at spark energy 2 and it was hovering around 62V which seems low. Saw a similar thread from a guy on this forum with an HS-350 but never saw a resolution. Hoping someone can offer a few clues or experience. Thank you.
What are your other settings?
I've tried various combinations and the result is the same, wire breaks after a few arcs with seconds of delay in between sparks. Last settings were Spark energy = 3, Spark rate = 15, Wire Feed = 6, Tension = 6, can't recall others. I've recently noticed that LED#3 on the sub-discharge pcb is lit when running(circled in pic below) According to the service manual it means main discharge is prohibited. I don't know if it goes out once it clamps though. Also have a new issue(possibly related?) now that the machine stops without any alarms or wire breaks. I saw in another post that you're thinking of selling yours. I may be interested. I'll PM you on that. 1722172503758.png
May I ask what you are cutting (material, thickness) and your flushing/submerged conditions, water readings?
Cutting 1/4" 304SS, submerged with lower and upper flushing set to 6/7. Water cond 3-4, i've tried from 1-5 with no change. Curious if LED#3 on the sub discharge pcb is illuminated on yours before it's cutting and afterwards.
