How so? If the non licensed holders are not ground to spec they can do what they're doing. These are making more face contact than taper. That's would mean it's a holder issue. If it was drawbar it would not have enough strength to pull the face all the way up. leaving a gap. That's not what's happening here. I could be totally wrong but that makes sense in my head. I have spoke with Brother(Yamazen) about this and that's what they think also.
You came here asking for advice, yet refuse to consider anything other than what you already diagnosed yourself in post 1. Quite a few of us are pointing you in the same direction, towards the solution, and even if it isnt, you will know exactly what is before spending money on tool holders you will likely be damaging.
Not being licensed does not necessarily mean not in spec. And multiple holders from multiple oems makes the odds more in my favor...
Whats the one constant in this, the spindle.
You are confusing the fretting symptom, you have taper contact, and very light face contact, fretting happens when there is light contact and movement.
How would you have light contact on the face, low drawbar force.
How would you have slight fretting in the taper, low drawbar force.
How would you have tool movement in the taper, low drawbar force.
Also if you just had face contact, nothing would be centering the tool, you would have excessive runout, imbalance, inconsistent sizing etc.
All the symptoms can be explained by low retention force, a taper issue or a cut that is too much for the tooling interface, but most likely a combination of all of the above.
The things you have convinced yourself that are facts, just arent.
Why do you think drawbar springs dont weaken/crack/seize and fail? You said you never heard of it, so it must be a fact.. wrong, I see it daily.
Why do you think a 2 year old spindle cant have issues? I see them every day.
Even if you cant get a retention force spec from the oem, there are standards for iso tapers 30, 40, 50, 60, hsk, sk, capto, km, etc that will tell you if you're in the ballpark.
