Chips Everywhere
- Apr 29, 2021
Thank you everyone for the feedback, was able to shave off 1min off my cycle time.
I looked up your end mill, it is a rougher/finisher, which work a lot more like a finisher than a corn cob rougher. Try a Garr corn cob rougher #46303, get 3 of them so you can break one seeing how fast you can feed it. I looked at their speeds/feeds chart and it is hopelessly conservative so ignore it. MA Ford has a much more realistic one for their same type tools. For side milling they show up to a .035" chip load with a 3/8" mill, yes that is per tooth, which is realistic. I can't give you specific parameters to use since they totally depend on what you are doing, and how well you can hold onto your part AND flush the chips out. You may not want to run full rpms so once you get the machine making parts play with the over rides to see what you think you can do. You may be better dropping your rpms so you make fewer but larger chips that are easier to flush. Don't get hung up thinking you know anything, just play with the feeds and speeds for a while, and don't be afraid of breaking an end mill, that is why you got extras. If you do this I can guarantee you will end up running that rougher far harder than you ever imagined. Play with width of cut too, I like around 40% with corn cobs when side milling. That would be around .15" with a 3/8" mill. That might be a little much at 1" doc but it might not too.Helical # 82012
Can you please share what parameters you use for a 3/8 end mill.
We snap off 3/8" roughers from time to time, usually from misloaded stock (never from my programming, of course....). The pull stud doesn't care, especially with the stubby holders (these are the Maritool high strength stud).My biggest concern right now is the BT30 pull stud, after seeing one for the first time a week or two ago, it really made question how fast I can rough on a BT30. That's why I started with 180imp. I'm not saying they are not capable of roughing, I'm just afraid of snapping the pull stud and not the end mill. I'll order some of those end mills and give them a try.
The problem with BT30 pullstuds is NOT the studs, it's the 500-600lbs of drawbar force on many machines. What generally breaks the studs is when the drawbar force is overcome pulling the holder partially out of the spindle. Since it is in the cut the holder is held to the side rolling around in the spindle so the pullstud is at an angle to the drawbar. This rolling side load is really hard on the pull stud. I think Maritool pull studs are through hardened and are a bit more sensitive to this side load. This is why you need to keep your projections to a minimum and be careful of using tools that pull too much like bigger end mills and high helix. A common problem I have with my parts is holding onto them so I am pretty sensitive to cutter pressure and lift. Corn cobs for roughing really reduce the cutter pressure and greatly reduce the lift so I can run them much faster without the parts moving.My biggest concern right now is the BT30 pull stud, after seeing one for the first time a week or two ago, it really made question how fast I can rough on a BT30. That's why I started with 180imp. I'm not saying they are not capable of roughing, I'm just afraid of snapping the pull stud and not the end mill. I'll order some of those end mills and give them a try.
IF true that would change a lot of our advice, but I would want to verify it. With that much drawbar tension tool projection would no longer be so important. That is also a very big range.The spec on the Haas website claims : 920 - 1420 lbs
Notice
