Brett W
- Jan 10, 2014
- Huntsville AL
Since I build race cars and parts, I have an interest in the gear machining process as well as splined shafts. What type of hobbs are used for normal automotive sized parts?
Depends on the part. Long skinny things like axles is one thing, basic helicals another, blind back-tapered teeth like a synchro are another. Helicals, spurs, splines, sprockets will all use different methods depending on the part.What type of hobbs are used for normal automotive sized parts?
The minute you start talking synchros, you get into complexity ...... gears with syncros, straight cut gears with syncros ... but broaching splines in hubs would be a useful capability.
Guess I would need the ability to do both, so cutting helical gears is useful, but without the ability to cut the internal splines, its kinda of useless.
Used to be. Now you can just throw money at it. Big money. Zeiss, Hoefler, Gleason ... they all have computerized measuring machines that will give you back the data you want.It is very hard to measure a gear and then copy one
Too slow, except for big one-off spiral beevils. If'n I was crazy and wanted to do short-run automotive, I'd get :Indeed And then a 5axes machine The software from klingelnberg and go at it
The synchro teeth themselves are cut with a back-angle usually on a shaper with a tilted table. There's one machine for ya. Then another to point the teeth.
Synchro tilting isn't like tramming a Bridgeport, usually they tilt the whole top half of the machine, so you pretty much set up one machine for just that process.
The teeth, not on all but on just enough to be annoying, can't be hobbed because the synchro teeth get in the way. Need a shaper, with cutters for that specific lead AND a helical guide (used to be $3,000 plus, I don't dare think what they run now) to give the cutter the twist it needs traversing the face.
There have been some experimental and weirdo cnc attempts to do the twisting electronically, either big money or big trouble, take your choice.
Spur teeth are usually straightforward, either hob or shape depending on the geometry of the blank. In practice you need both You'd like to hob as much as you can but sometimes there is stuff in the way. Shaper time.
As far as the internal splines, you used the right word, broach. For which you need a broaching machine and a broach, to match every spline you want to cut.
Involute splines you can do on a shaper with an internal cutter, but an awful lot of automotive shafts are straight-sided. Can't very well do straight sides with an internal cutter because of the way the parts revolve with the cutter during the generating process. It can be done with a single tooth cutter in an nc shaper tho. CNC gear shapers are also pretty expensive, even twenty year old ones.
Obviously can be done because there are people doing it but it's not something you want to get into casually. Doing a couple of parts is reasonable but the wide variety you described, that's a lot of tools and equipment to buy.
I had a question, within a specific context. If the goal is prototyping one off gears rather than production, can a multipass or some other strategy push that rating?Hobbers aren't rated just by size, they are rated by the pitch they will cut. That Mikron would struggle with 16 DP. It's probably happy with 24 DP and finer. (....)
Notice
