projectnut
- Mar 4, 2006
- Wisconsin
Recently I picked up a used (11 years old) Baileigh CS-350-EU cold saw. I'm in the cleanup stage and getting ready to reassemble it. The saw has been used in a production situation since new and is now covered in dried and semi dried water-based coolant. At this point I've removed several pounds of slimy crud from just about every surface on the machine. It's going fairly well, but I'd like to not have to go through the process on a regular basis.
When reassembled the saw will be used as a backup for my Startrite horizontal bandsaw. As such it will probably get less than 5 hours a month runtime. I dislike water-based flood coolants in that they always seem to stagnate and smell over time, make a mess on the shop floor, and require the machine to be disassembled and cleaned on a somewhat regular basis. For the limited use this machine will get I'm considering the use of a stick lubricant like Cut Ease, or a manual or automated spray mist system. Has anyone tried this, and if so, what were the results?
