SShep71
- Sep 17, 2014
- San Diego, Ca
Here are the listings I put up on Ebay today. I have more to put up another time. The inserts are almost 1.00 each, buy the lot, split them up and list them individually, make lots of money. I just don't have the time, and want the stuff off my bench. All the stuff is for sale locally, so if you live in the area I can meet you or you can just come to the shop.
-Large lot of carbide and ceramic inserts almost 1000 pieces. Iscar, Sandvik, etc
-(2) Servo power feed models 150 and 100
-Solid Carbide Coolant though drills Kennametal, Walter, Ma ford
-Press brake die lot
-OSG powdered metal metric drill lot, for hard materials, VPH series
Large lot of carbide and ceramic inserts almost 1000 pieces. Iscar, Sandvik, etc | eBay
ISCAR LNKX 150608ANTN 2 20 0 20. ISCAR FF WOCT 09T320T 1 10 0 10. ISCAR TPGB 2-1-XL IC20 1 10 0 10. ISCAR XCMT 120408 IC908 1 4 0 4. ISCAR TPG 321 1 8 8 0. ISCAR HFPR-6030 IC656 1 8 0 8. ISCAR GRIP 3003Y IC418 1 2 0 2.
www.ebay.com
(2) Servo power feed models 150 and 100 | eBay
Here are (2) Servo power feed units. The 100 model works flawlessly, the 150 model does not have the switch to test it. I rebuilt the 150 model two years back, it was never used since as I never got a switch to test it.
www.ebay.com
Solid Carbide Coolant though drills Kennametal, Walter, Ma ford | eBay
(1) Used Walter A3389DPL-7.5 I think it's used I just don't have the box.
www.ebay.com
Press brake die lot | eBay
They are ideal dies for a swag or similar conversion kit, or just in general for a standard press brake. There are a few different corner radii for the upper die. 4-1/2" tall top die lengths: 3", 4-3/4", 5", 5-7/8", 6", 7-1/4", 8", 39-1/2".
www.ebay.com
OSG powdered metal metric drill lot, for hard materials, VPH series | eBay
Lot of OSG drills (26 pieces, plus one KEO center). "The VPH V-series drill line is the ideal drilling solution when dealing with exotic materials like Inconel and when through tool coolant is not available.
www.ebay.com
