52 Ford
- May 20, 2021
I have a plasma cutter but no dedicated cutting table. Most of them I see have have steel slats to support the stock and I guess you just have to deal with them as consumables. I've been making cuts on some small-ish pieces - Mostly 4 to 12 inch long cuts in approx. 1/8" tool steel plate - and think I would benefit from a small plasma table. Maybe 3 foot wide and 2 feet deep.
I was thinking a out how I want to build it and decided that easily replaceable slats is a must. The obvious solution would be a bunch of slots (edit: to drop the slats in) - which is what I'll probably do, but my other idea is as follows; drill holes instead of slots and instead of steel slats, use steel round rod with ceramic tubes on them. I found a cheap source for 9.5" long ceramic tubes that I believe are meant to protect heating elements in a particular brand/model of electric grill. I guess they're considered a consumable because of the grease that'd get dripped on them. Since the tubes are only 9.5" long, I'd have pieces of steel plate coming up to support the steel round rod between each section of ceramic tube. They'd run front to back, and the supports for the round rods would be left to right and have the holes in them.
The only reason I can think to not use ceramic is it could crack from thermal shock. Or if I drop something on them they would shatter - obviously.
By the way - I still haven't made those insoles I was talkin' 'bout. Too many projects. Keep getting distracted.
