dsatchell
- Oct 24, 2022
I have been following a lot of the tips on the site to little avail. It's really perplexing.
My project is refinishing 2 1x2x18" parallels. these came to me used, and were generally in good condition with the exception of a <0.5 thou warp in them (top and bottom face (1x18" surfaces)), I can clearly measure both the hump and the concave sides, and a flatness friction test on a surface plate is consistent (hump side spins the part near the middle, concave side spins the part on the ends.
I set up on the grinder with a minimal magnet setting, so low that I can still measure the hump and push the part around by hand pressure. both sides are marked so I know which is high, and grind. it then measures flat. I'm grinding about 0.1 thou per pass with flood coolant.
Once done, I test the side for flatness on a surface plate by friction, all good (now spins at about 6" from the end), and then switch the sides, use full magnet, can again measure the ends now high, and grind. while still on the magnet with residual setting, I measure and it measures flat.
Remove from the magnet, clean and BOOM, I have the warp again.
I have noticed that the material does load in the wheel and have had to start resurfacing the wheel for each side. Generally finish is quite good.
I don't remove more than 1 thou total per side, and i've done this 4 times with similar results. I didn't keep good enough track to determine if the bow side is switching, but I think it is, as if it is springing from one side to the other.
the grinder has an 18" magnet, and I conducting the grinding parallel to the wheel. I'm going to try setting the pieces off angle and determine if that helps.
Other insights would great.
