moonlight machine
- Nov 19, 2007
- marysville ohio
It has a 2.75 Dia. hole on center. faced flat to a diameter of 5" Then a 2.5 degree taper out to 9". Chatter was bad at any speed or feed. I made big pie jaws and that helped but not enough. I solved it by cutting 2 wood blocks with a small taper. I put them through the center hole and between the part and the chuck with just enough pressure to keep them from falling out when the spindle is stopped. Results were instant, no more chatter, beautiful finish.
