markp
- Oct 7, 2006
- Petaluma CA 94952
Ive got a 94 Cinci Sabre 750. I recently picked up a new old stock spindle with the factory certification papers. My old spindle is still ok but getting a little old in the tooth and this one was cheap. My original spindle was grease lubed and still had a small amount of grease in the bearings. It has 3 grooves on the spindle taper end for a labyrinth seal. No holes in the presetting cap. Photo below. The new spindle has very little grease in the top bearing, maybe 1/2 of a BB size drop at each ball. A little more on the bottom bearing that I can see. Definitely a little less than the old spindle bearings. Photo below of new spindle upper bearing.
The new spindle has a part number on the paperwork of M161233 and is the same in every dimension but has a different configuration on the taper end labyrinth seal. The taper has a cup that fits into a corresponding recess in the presetting cap and there is a small hole drilled into the presetting cap for drainage. Photo below.
My concern is that this is one of the oil lubed spindles and the hole is for oil drainage only, and the grease is in there for assembly only and just gets washed away in an oil lubed Cinci . Anyone know for sure about the physical differences between the two types? If it is oil lubed, Im thinking I can just wash it out and relube with Kluber.
