Ranchingelec
- Sep 12, 2006
- Meadow Lake, Saskatchewan
Hello all. I have been brousing here for a while now and have learned much from you all. I figured it was time to throw a problem out to you fella's hoping you can help me. Last spring we purchased a 14X40 Craftex(sold by busybee here in Canada. It is very similar to some of the acra models I have seen) For things we do on the farm this will be and has so far been a great machine. My problem is with the compound Backlash. It was tight when we got it but after a couple of hours of machining, it loosed up. It could be turned one full round before engaging the threads either way. Upon further inspection I noticed the play was in the thrust bearing on the front of the threaded rod. I disasembled the handle, tighted up the nut and jam screw that tighted the thrust bearing. It was tight for another couple of hours of work. Then I noticed it was loose again. I may have to disasemble the compound further to find out what the real problem is. It seemed that the nut was tight as it could be. Anyways I was wondering if any one has experienced this. Any opinions would be greatly accepted, unless it is about "shoulda not bought that Tiawan product.) lol
