I know this topic comes up from time to time but I thought I would get some input for my specific application.
Basically I have 5 mills in the shop, a water jet, robot and some other stuff that that can suck a lot of air. The compressor room has 2 - 5hp piston compressors each with 80 gallon tanks. The one air compressor is my dads old one with a tag from 1969 the other is a fairly new Quincy. I was wanting to retire the old one but this summer switched it back to the main compressor because it doesn’t have any thermal overloads and just runs.
There is also a 350 gallon capacitor tank on the back of the shop that bought me a couple years on upgrading the compressors.
The “main” compressor never stops running and the other compressor runs alot of the time. Generally speaking 10hp of compressed air will keep up but not always.
Lately we have been running an air blast on one machine nearly all the time. This is by far the biggest air user but I don’t see any alternative to air blast.
Lately we have bypassed the air drier because it doesn’t keep up and is the weak link.
The water jet needs real dry air for the garnet hopper so the machine with air blast doesn’t run at the same time the water jet runs. Which is irritating.
Should I:
1. Upgrade the drier? And use 10hp of air?
2. Buy a better air system? If so what kind? New, used? Used a person can get 20-40hp and a drier fairly cheap from industrial surplus places but they are at least 10 years old.
3. Plum up one compressor to the airblast? I’m cutting plastic so it can be wet air.
4. Something else?
Should I:
4. Something else?
