Hi Daniel G:
My experience with compression molding silicone is pretty limited but there are a couple of things I remember.
(I did a project involving escape respirator exhaust valves back around 2005 or so.)
So the things:
1) The project was far more successful when we went to a transfer mold compared to a bog standard compression mold that you pack from the parting surface.
We were molding low durometer flurosilicone and it was a bitch to cryo deflash, so transfer molding helped a lot. (less flash to start with)
2) Our first prototype mold was aluminum, and as I recall, the silicone stuck to it badly; I believe we ended up going to NAK 80 and that was fine.
You can crowd a lot of cavities together with a transfer mold...ours was about 6" x 6" and had 9 cavities in it each about 3/4" diameter if I recall right.
The tonnage on a transfer mold is not that high but I can't recall what it was.
You still have to get the uncured silicone from the transfer pot through the gates into the cavities (0.025" round gates for my parts, I believe) so you do have to give it a bit of grunt but nothing like injection molding.
I believe the gates were about 0.025" tall too, and nothing bent when the mold was squeezed in the press, so not much tonnage.
I want to say the transfer pot was about 4" x 4" but I really can't remember if that is true and the files are long gone so I can't look it up.
So that's it for what it's worth.
Hopefully that is of some use to you.
I gotta ask though, why are you planning to prototype using this process?...there are several others available to you including gravity pour urethanes and 3D printed flexible plastics too.
Cheers
Marcus
www.implant-mechanix.com
www.vancouverwireedm.com
