Compressor pump identification?
rons
Mar 5, 2009
California, USA
The two stage pump has this printing on the crankshaft casting.
The orientation of the characters is parallel to the crankshaft.
H100 213
On the wheel side there is:
H31-753
A nameplate that is stamped near the bottom on a surface that is perpendicular to the crank.
MOD. 5000
SER. 4005X10240
Would like to know about this and find out the Hp/rpm.
rons
Mar 5, 2009
California, USA
Blast from the past ....
Is it still easy to buy rings and pistons, cut your own gaskets. The bottom end is just like a motorcycle.
BT Fabrication
Nov 3, 2019
being 2 stage, probably needs min a 7.5 hp motor to run it. and standard 1800 rpm motor on a id guess 10 or 12" pulley and 3.5" on the motor usually
