updatedsecurity
- Jun 6, 2021
Hello.
I recently got a new machine that requires about 18cfm. I would really like the idea of a screw compressor because its quiet and has a dryer in it. My questions are these; Apparently the screw compressor needs to have a 100 percent duty cycle. The machine when sitting does not really use the full 18 cfm. What does the compressor do when the machine sits idle? Does it just keep cycling? Where does it put the air that is not being used? What happens if the machine is rated for 18cfm and the compressor for 24 is that bad for the compressor?. At the moment I am making do with an old piston that runs about 30 percent of the time. Its loud and the air coming out of it is hotIt has a bunch of dryers and filters on it but the noise and the constant on off cycle is annoying.
I got quotes for an atlas copco for about 9k and one called kaishan for about the same. I am also looking at the KairFree from kaiser which is their compressor leasing thing where you just pay 2.2$ for each hour the compressor produces air and they do all the maintenance and quarantee no down time.
Thank you
Thank you
