I have had a bit of a foaming issue with coolant, and now I am seeing some rust. This is happening under the vise, inbetween things, places that don't dry out for a very long time. It doesn't seem to happen on any surfaces that dry.
Some people have recommended DI water in the coolant mix. I have used well water, it is treated to remove iron and maganese through a improved green sand filter. The cheap test strips put it at about 120 - 150 ppm total hardness. I don't have a TDS meter. The reading I have done suggests that DI water is actually somewhat more corrosive than hard water. But also that the hard water may bind up the anti-corrosive additives in the coolant, so maybe DI water is better. I get quite a bit of evaporation between uses, mill will go several weeks not being used, then I have to top up the tank with 10 or 15 gallons of fresh mix. I test the concentration and keep it at the high range - about 10%. But if I am adding that much water lost through evaporation, surely I am increasing the hardness over time too.
A DI filter will cost a few hundred, not the end of the world but money I would rather spend on beer if the DI doesn't do any good. So:
Who has experience going from tap or well water to DI water, all other things being the same? What was the result? Improvement or no, dramatic or marginal?
