M.
Adjusting the pilot diameter of my modeled tool is the only way I know to pick up the point of tangency perpendicular to the spindle axis. Adjusting the height offsets is the only way I know to pick up the point of tangency in Y. As I am running the tool around the entire part, once I get these correct for the first side I expect that it should not change as my tool goes around the part ... as long as the tool stays in a fixed plane. But, sadly, as I turn the corner and come around the end of the part the tool plows into the material as it comes down the side parallel to the side it was adjusted for. The tool does not seem to work for the edge in the same axis and plane of the one where it was previously working well.
