Hey everyone,
Young machinist here, having some trouble with surface finish on a CPVC part.
I'm only cutting 0.1" deep into the part with a 0.05" finish pass. O-flute 1/4" spiral single flute at 18,000 rpm x 200 ipm.
Notice the dwell marks that show up at points where the cutter changes direction. These marks are over .01 deep. I have tried creating a toolpath that starts outside of the part and only makes radiused turns but have not figured out a way to completely avoid tight corners.
50hp vacuum pump pulling plenty of vacuum. Newer Onsrud machine. Spoil board is getting a bit thin but I don't think that's the issue as I pocket UHMW parts just fine. Perhaps a different cutter would be recommended (I'll talk to my tooling guy on Monday).
Any recommendations for you all is more than welcome!
