That didn't answer th question I asked. I do not have enough space to undo the leadscrew nut in the gearbox. I am trying the remove the end bracket bearing block. As seen on this previous poster DSG lathe: replacing the power feed drive key
I am going to end up damaging the leadscrew, and feed shaft if I just continue to try and beat the thing off, the 2 locating pins are the issue but I'm not sure how to remove them. Does anyone who has a dsg 1709 or similar wanna give a buck a hand.
If it’s the “ locating pins “ I think you mean, you need to pull them out with a slide hammer. Do that before you undo the cap head screws that are holding the bracket in place.
Regards Tyrone.
Cheers buck.
Only problem now is the thread appears to be 5/16" BSW which appears to be totally unavailable for any thread puller. Can't even get BSW threaded bar in the EU. I'd be tempted to cut them or some other destructive removal method.
Cheers buck.
Cheers buck.
I suppose a lot depends where the bearing is going ?This should probably be in some other area of the forum my question is:
New Bearings or Old Bearings?
Is there any reason to use or not use a newer NSK Bearing than say the Original R&M Bearing
NSK is cheaper by about 50% just to clarify.
The auld bucks on here will have more wisdom than I so I'll leave it up to ye.
Cheers
Probably going to replace almost all bearings in the lathe bar the spindle bearings which are so expensive i could buy another lathe with it.I suppose a lot depends where the bearing is going ?
Regards Tyrone.
Notice
